 Sujet du message: Transformateurs
MessagePosté: Jeu 29 Jan 2009, 09:19
Désolé, c'est en Anglais !
Mais il y a quelques dessins :roll:
http://sound.westhost.com/xfmr.htm
Et expliqué de façon claire et simple.
Have fun.
La traduction automatique n'est pas si mauvaise que ça:
http://translate.google.fr/translate?hl ... f%26sa%3DN
Que du bonheur !
MessagePosté: Jeu 29 Jan 2009, 14:04
Excellent Yves,
Cela permet de "débroussailler" un peu la complexité du sujet ...
MessagePosté: Jeu 29 Jan 2009, 16:05
Salut Daniel.
J'attire tout spécialement ton attention sur ce passage:
Code:
12.   Some Measurements
I measured the characteristics of a small selection of transformers to give some comparative data. I excluded regulation from this, as it is difficult to make a suitable load at short notice, and loads tend to get rather hot even with short usage. Most manufacturers will provide this information in their specifications, but be warned that this refers to a resistive load, and regulation will be much worse when supplying a conventional rectifier and filter capacitor (see above, and the Power Supply Design article for more details). It is also worth noting that an inductance meter is often of little use with large iron cored transformers, unless it operates with a sinusoidal waveform at (or near) the design frequency of the transformer. The inductances shown are calculated, since the measured values with my meter were a long way off.
Type   Rating   Inductance   Resistance    Turns/Volt   Magnetising   Core Loss   Reactance    Mass (kg)
Toroidal   500VA   34.7 H   2R4   2   22mA    5.28W   10.91k ohms   5.0
Toroidal   200VA   63 H   5R1   3   12mA    2.88W   20k ohms   2.7
E-I   200VA   4.36 H   6R6   2   175mA    42W   1.37k ohms   3.2
Table 7.1 - Measured Characteristics of Some Transformers
The toroidals are clear winners in terms of core loss in particular, but it must be said that the E-I transformer tested is not really representative of the majority.
Et plus particulièrement:
Code:
This is one of a few left that I had specially made, and they were deliberately designed to push the saturation limits of the core. These transformers run quite hot at no load, but give much better regulation than a more conservative design - the vast majority of such transformers. They were actually designed to run just above the "knee" of the B-H curve for the laminations used, and although somewhat risky, none has failed (to my knowledge) since they were made about 20 years ago. I use a pair of them in my hi-fi system, which has been in daily use for 10 years now.
It is also worth noting that the mass is lower than for a more "traditional" transformer design - a conventional design of the same power rating would be expected to weigh in at about 5kg.
:wink: :wink:
MessagePosté: Jeu 29 Jan 2009, 16:50
Salut Daniel.
Code:
Code:
:wink: :wink:
N 'étant pas Anglais d 'origine mais Gaulois de Bibracte une traduction serait la bienvenue...a vot bon coeur.
MessagePosté: Jeu 29 Jan 2009, 17:16
Traduire est un boulot dingue !
Je pourrais te le lire, mais remettre en forme avec un minimum de style, c'est un métier en soi.
J'ai regardé le résultat produit par les "robots traducteurs":
C'est quelquefois un peu comique (le robot ne connais pas la signification de certains mots employés dans un contexte "technique" et en reste à leur signification literrale, pour parler d'un "coude" dans une courbe, les anglais disent "genou", alors le robot traduit par "genou"), mais à mon avis, ça vaut la peine d'en chier un peu.
MessagePosté: Jeu 29 Jan 2009, 18:31
Salut Yves
Intéressant.
Pour les Noratels, les specs donnent les résultats suivants pour l'enroulement primaire (230V), mais c'est les specs, pas du mesuré, sauf les 3.5sp/v:
Rating----PrimaryR----Turns/Volts----Magnetising----CoreLoss----CopperLoss----Mass
500VA----2.06ohms----Inconnu----30mA----3.53W----23W----4.2kg
300VA----4.18ohms----Inconnu----19mA----2.23W----17W----2.9kg
225VA----6ohms----3.5sp/v----16mA----1.8W----16W----2.25kg
MessagePosté: Jeu 29 Jan 2009, 19:15
Ok c 'est déjà mieux que rien.... ceci dit je vais essayer de me démerder parce que j 'ai quelques rudiments d 'Anglais technique, et puis queqluqes relations feront le reste.
MessagePosté: Jeu 29 Jan 2009, 20:36
vapkse a écrit:
Salut Yves
Intéressant.
Respectivement:
25H, 39H et 45H à 230V/50Hz.
Si tu peux estimer les dimensions du noyau: section et diamètre, on peut pousser le "back engineering" un peu plus loin . . .
MessagePosté: Jeu 17 Sep 2009, 20:50
bonjour
Pas vraiment en rapport avec la discutions ci-dessus mais bon, je squat.
Je lis dans ce post: http://www.audiyofan.org/forum/viewtopi ... n&start=30
...que ce ne sont pas les watts qui saturent le transfo mais les volts :shock:
Ya bien un rapport avec les watts sinon comme je suis con je vais pas regarder les VA pour choisir mon transfo de sortie...
en fait je regardais les transfos pour montage sur circuit imprimé, mais sur radiosapre ya pas mieux que 52 VA. (81% de rendement soit dit en passant c'est nul non ?)
Ceci serait pour un circlotron 2PPECL86 donc 25W environ.
Je me demande comment dimensionner le transfo. voila voila.
MessagePosté: Jeu 17 Sep 2009, 21:28
benou.1 a écrit:
bonjour
J'aurais du dire "qui saturent les tôles" !
Un transfo 110 Volts branché sur 220 Volts défuncte en quelques minutes même sans aucune charge au secondaire, donc sans fournir aucun "watt".
Simplement parce que l'induction (en Y et proportionelle à la tension) a atteint un niveau que les tôles ne supportent pas et que la perméabilité (en X) s'effondre et en conséquence l'inductance primaire (Lp, proportionelle à la perméabilité) aussi.
En langage de bobineur pour courants industriels, ce sont les pertes "fer" et le courant primaire à vide.
Ben oui pour la puissance à transmettre (diamètre des fils, pertes par effet joule etc ...).
A la louche, 25W : 2,5Kg :wink:
C'est grossier, mais pas le double ni la moitié !
MessagePosté: Ven 18 Sep 2009, 06:38
A la louche, 25W : 2,5Kg Wink
Ca c'est pragmatique :wink: 980g max chez radiospare pour montage sur CI :(
Faut que je me trouve un variac pour tester les transfos...
 Sujet du message: Re: Transformateurs
MessagePosté: Lun 26 Juil 2010, 16:43
aussi en anglais:
The electric power engineering handbook
Par Leonard L. Grigsby
aperçu:
http://books.google.fr/
voir aussi:
http://www.transformerscommittee.org/
hervé
